Jettbett
Feb 20, 2021Aspirant
Nighthawk R6700 failed to optain IP address
Nighthawk R6700 firmware V1.0.2.16_10.0.57 Started upgrading home and adding smart switches, thermostates, garage door openers... Started having issues with devices going offline at random times. ...
antinode
Feb 21, 2021Guru
> Their are appox 32 devices that connect when the one SSID is active.
Claims have been posted here about a 32-device limit per radio. (The
router as a whole should be able to handle more.)
> Any suggestions?.
Adding a wireless access point should let you spread the devices
across more radios. Or, if you have devices which can use the 5GHz
band, or wired connections, then move them.
Jettbett
Feb 28, 2021Aspirant
I discovered that my xfinity modem/router was not in the bridged mode once I bridged it, reset the system with my Orbi RBR750 as the main router and hooked up the additional router everything is working fine. I now have well over 40+ smart devices hooked up and operational. We'll see how reliable it is in the coming weeks.
