Martin_AH
Dec 03, 2021Aspirant
Nighthawk R7000 - admin interface never reports firmware update available
In the several years I've owned my Nighthawk R7000, the web admin interface and the Ios Nighthawk app ALWAYS respond to Check for update with "No firmware update available". Repeatedly when this happ...
Dec 03, 2021Guru - Experienced User
- Martin_AHDec 04, 2021Aspirant
R7000 firmware is V1.0.11.126_10.2.112.
Connected to Actiontec MI424WR-GEN3I with firmware 40.21.24.
Thanks.
- FURRYe38Dec 04, 2021Guru - Experienced User
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATThis maybe blocking the update services that the router is trying to reach.
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setup- Martin_AHDec 06, 2021Aspirant
I am set up with your option 3. Radio is off on router, and NG is set to AP mode.
Is it because r7000 is in AP mode that it fails to recognize when firmware updates are available?
Thanks.
