Morgan1132
Dec 28, 2020Aspirant
Nighthawk R7000P Port Forwarding Not Working
Firmware V1.3.1.64_10.1.36 I have a Synology NAS which is setup to automatically connect to router and setup required port forwarding using UPnP. I am also using Synology DDNS service. I hav...
- Dec 28, 2020
Turns out my suspicions were correct and it was ISP settings. Quick 2 minute webchat to my ISP and everything is woring correctly. Wish I had of started here...
Hopefully someone trawling forums for solutions comes accross this.
Morgan1132
Photos appear to be working now. I'm starting to suspect its something to do with ISP setup? How can I troubleshoot further? My only concern is where some others have mentioned updating firmware or even rolling back firmware has solved uPnP issues
Morgan1132
- antinodeDec 28, 2020Guru
> Turns out my suspicions were correct and it was ISP settings. [...]
That (non-)description conveys approximately no useful information.
> [...] Quick 2 minute webchat to my ISP and everything is woring
> correctly. [...]The _chat_ solved it, or did you need to change some setting(s)
someplace?> Photos appear to be working now. [...]
If your server's LAN IP address is "10.0.0.10" because there is
(was?) another router between your R7000P and your ISP, then that would
explain many things.> [...] I used powershell command to test connection, [...]
Now that I can see it, that makes less sense than I had expected.
What was the point of those "ping" tests?
> Hopefully someone trawling forums for solutions comes accross this.That might be nice if there were some useful information here. What,
exactly, do expect anyone to gain from a (non-)description like yours?
