camjones1708
Feb 02, 2021Aspirant
Nighthawk R7960P Preventing intranet services (SSH, Bounjour, dropping packets)
My setup is the Nighthawk R7960P sitting behind the AT&T provided all-in-one modem with the wi-fi turned off. The nighthawk is connected with its WAN to the LAN of the AT&T router. My reasoning for t...
- Feb 05, 2021
The effect you are fighting ref. your RasPi and the random access does very well indicate there are multiple devices with the same IP address ou your network (LAN and WLAN).
Leaving the names alone (no clue what Netgear is riding since they have added this attached device detection): Are the systems on the network with fixed IP addresses? If all devices are DHCP, has everything be cold booted, starting with the router? Check the view with each device coming back to the network, review each device config, ...
camjones1708
Feb 04, 2021Aspirant
Yes, those are the device IP's as well.
I will try and get through that process tomorrow and see if it sheds any light on the scenario.
camjones1708
Feb 05, 2021Aspirant
After resetting the configuration, I am able to SSH and connecting to the printer. The only weird thing is that IP Allocation does not seem to be working anymore. I suppose that's not the end of the world though.
Also noticing the naming of the devices is being weird as well.
- camjones1708Feb 05, 2021Aspirant
Picture of IP Allocation Table
I just noticed that after adding the static IP Allocation for those two devices, it seems that there are multiple assigned the same IP? In addition, I can no longer SSH. Does that make sense? (I restarted the router after adding in those two rules).
- schumakuFeb 05, 2021Guru - Experienced User
camjones1708 wrote:Also noticing the naming of the devices is being weird as well.
Can't spot anything weird. These are the names the devices provide with the DHCP request....
camjones1708 wrote:Picture of IP Allocation Table
This shows two address reservations for IP<->MAC pairs along with a comment. What should not work now???
camjones1708 wrote:I just noticed that after adding the static IP Allocation for those two devices, it seems that there are multiple assigned the same IP?
"...seems..." ...---... where, how, why?
camjones1708 wrote:In addition, I can no longer SSH. Does that make sense?
No. Except there would be more devices on your network with that very same IP address why ever...
camjones1708 wrote:(I restarted the router after adding in those two rules).
Why ever...
I included a screenshot in a previous post of the attached devices. There are two devices with the same IP: 10.0.0.8.
I agree, that would be a router issue right?
Why ever...
The IP addresses were not changing after adding the rules.
schumaku wrote:Can't spot anything weird. These are the names the devices provide with the DHCP request....
There are quite a few devices that all received my windows desktop name in the allocation table screenshotted. - schumakuFeb 05, 2021Guru - Experienced User
All are DHCP, so restarting seemed to resolve the issue.
Current setup is AT&T modem in passthrough mode, Nighthawk in router mode with default settings excluding two static IP addresses allocated, and custom Wifi SSID/password.
Thanks for the help! I'm not really sure what was wrong on the previous configuration, but this seems to have resolved it. I can see my printer as well.
