camjones1708
Feb 02, 2021Aspirant
Nighthawk R7960P Preventing intranet services (SSH, Bounjour, dropping packets)
My setup is the Nighthawk R7960P sitting behind the AT&T provided all-in-one modem with the wi-fi turned off. The nighthawk is connected with its WAN to the LAN of the AT&T router. My reasoning for t...
- Feb 05, 2021
The effect you are fighting ref. your RasPi and the random access does very well indicate there are multiple devices with the same IP address ou your network (LAN and WLAN).
Leaving the names alone (no clue what Netgear is riding since they have added this attached device detection): Are the systems on the network with fixed IP addresses? If all devices are DHCP, has everything be cold booted, starting with the router? Check the view with each device coming back to the network, review each device config, ...
camjones1708
Feb 05, 2021Aspirant
schumaku wrote:
camjones1708 wrote:I just noticed that after adding the static IP Allocation for those two devices, it seems that there are multiple assigned the same IP?
"...seems..." ...---... where, how, why?
I included a screenshot in a previous post of the attached devices. There are two devices with the same IP: 10.0.0.8.
camjones1708 wrote:In addition, I can no longer SSH. Does that make sense?
No. Except there would be more devices on your network with that very same IP address why ever...
I agree, that would be a router issue right?
camjones1708 wrote:(I restarted the router after adding in those two rules).
Why ever...
The IP addresses were not changing after adding the rules.
schumaku wrote:Can't spot anything weird. These are the names the devices provide with the DHCP request....
There are quite a few devices that all received my windows desktop name in the allocation table screenshotted.
schumaku
Feb 05, 2021Guru - Experienced User
