Dharmajeet87
Aug 03, 2022Aspirant
Nighthawk router firmware update
My nighthawk router is blocking Hulu streaming after firmware upgrade.Please help.
michaelkenward
Aug 04, 2022Guru - Experienced User
There's not enough there to go on.
What Netgear router is this? What firmware have you applied?
What do you mean by "blocking"? What are the symptoms?
If you can't fix the issue, the first move is to reset the router and set it up from scratch.
- Dharmajeet87Aug 04, 2022AspirantRouter Model: R6400v2
Firmware Version: V1.0.4.122_10.0.95
I have tried to restore factory settings but no use.
Hulu is not working on any devices. Hulu error code: P-DEV302
I am able to login to Hulu but not able to watch any content. The above error is displayed after clicking on a content.- plemansAug 04, 2022Guru - Experienced User
I get what router you have. What modem/gateway is that router connected to?
- Dharmajeet87Aug 04, 2022AspirantI am not sure about the modem as it is provided my wave broadband and somewhere outside my house and the default gateway 152.44.216.1
