Dharmajeet87
Aug 03, 2022Aspirant
Nighthawk router firmware update
My nighthawk router is blocking Hulu streaming after firmware upgrade.Please help.
Aug 04, 2022Guru - Experienced User
Are you using armor or parental controls?
What modem/gateway is it connected to?
What error do you get?
Is it blocking it on all devices, just one?
- Dharmajeet87Aug 04, 2022AspirantHi Sir,
A1: I am not using armor or parental control.
A2:It is R6400 v2
A3: I am getting P- DEV313 Hulu error code while streaming any content
A4: Yes it is blocking all the devices.- plemansAug 04, 2022Guru - Experienced User
1. what modem/gateway is the router connected to?
2. what firmware did you install?
3. did you try a factory reset on the router? Maybe an old setting is causing issues.
