PropMgmt
Jul 14, 2022Aspirant
Nighthawk Router in commercial lobby setting
Hi, we are switching from ATT to Hotwire in a commercial office building lobby setting. The internet is now provided by Hotwire. We have installed the Nighthawk router #AC1200. To install it, we had ...
Jul 14, 2022Guru - Experienced User
Not sure what hotwire is.
1.Does it come with a gateway/modem device that you connect the router to?
2. AC1200 is a speed, not a model. What actual router do you have?
3. You can setup the router using the browser and not a personal device. You could simply factory reset it and reinstall using the browser. when it comes to the page that says "netgeaer recommends the app...." at the bottom of the page theres a link you can click on to continue and not use the app/phone.
