Melita
Apr 24, 2021Follower
Nighthawk router worth it? I will get a modem too
Currently in the market for used modem and routers. I am thinking about getting a night hawk router ac1900 used for cheap under 50 if I can. Then I will probably need a modem too. Now I am pretty ign...
Apr 25, 2021Guru - Experienced User
It needs to be compatible with your isp. Without knowing your isp you don't know if its fibre, dls, cable, etc.
those are key when picking a modem.
Contact the isp and they'll be able to tell you what's compatible or direct you to a list.
It might also be worth checking as some ISP's will give you a free modem versus some charge for a modem.
