tganus's avatar
tganus
Follower
Jul 06, 2020
Nighthawk to N300 wireless bridge for RJ45
I need an ethernet port for a space without one, for VoIP phone.  Network access is through R6260 wireless router in another space for wireless devices.  I have a working spare N300 WNR2000V2 router and wonder if I can wirelessly connect his N300 with my R6260 router for RJ45 Ethernet port access.  I won't need PoE.  The phone will have have separate AC power?
  • > [...] I have a working spare N300 WNR2000V2 router and wonder if I can
    > access. [...]
       What you want is called a wireless bridge.  Purpose-built wireless
    bridges exist.  Some router models can be configured to act as wireless
    bridges.  My quick look at the WNR2000v2 documentation suggest that your
    antique does not offer such a mode.
       Your local thrift store might offer more capable devices.
       If running an Ethernet cable would be very difficult, then there
    exist adapters to use existing power wiring or co-axial cables, instead,
    but these tend to cost more than plain-old Ethernet cables, and may be
    less fast and reliable.  A Web search for, say:
          powerline adapter
    and/or:
          moca adapter
    should find many things.
1 Reply
    > access. [...]
          powerline adapter
    and/or:
          moca adapter
