rachin99
Nov 15, 2023Follower
Nighthawk X10 AD7200 R9000 vs. AT&T BGW320
So I have a Nighthawk X10 AD7200 from about 5 years ago and just moved into a new apartment. Signed up for AT&T Fiber and they sent me a new router with installation. Would the X10 AD7200 be worth s...
michaelkenward
Nov 16, 2023Guru - Experienced User
rachin99 wrote:
Would the X10 AD7200 be worth setting up or should I just use what was given to me?
Just give it a whirl.
The R9000 dates back to 2017. With luck the AT&T BGW320 will be a bit more modern on the wifi technology front.
If you do decide to add the R9000 – to fill a wifi gap, for example – you can't just plug it into the BGW320. That would put you into "double NAT" territory.
What is Double NAT? | Answer | NETGEAR Support
You'd need to do something like Access Point mode with R9000. Or you could play with Bridge Mode.
To read about those options, visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
But that could get messy. So I'd just try the BGW320.
