paintstripper
Mar 13, 2021Aspirant
Nightmare Home for wi fi
I have a stone built house, some walls are two feet thick and all walls are solid. Getting wi fi round is difficult. Can anyone help? Is there a product that will pick up wi fi and transmit the si...
wcalifas
Mar 16, 2021Prodigy
You can try finding one of those mesh systems or have one router and various wifi access points (any router turned to an access point). You can wire through ethernet to the access point in a different room(s) to have wifi wherever you want.
paintstripper
Mar 17, 2021Aspirant
Thanks for the advice. Do you have any particular equipment/models that you would recommend to give me the best chance of getting wi fi round our difficult home?
