callwill's avatar
callwill
No 2.4Ghz network R6300V2
New to me R6300v2. When i set it up i enabled both the 2.5 and 5 networks with the same ssid and password.  Later found i only have a 5Ghz network, no 2.4. Disabled the 2.4 and the enabled again, no ...
  • plemans's avatar
    Sep 08, 2021
    first we update your firmware, then we can troubleshoot the wireless.
    So try updating, then do a factory reset and reinstall
