callwill
Sep 07, 2021Aspirant
No 2.4Ghz network R6300V2
New to me R6300v2. When i set it up i enabled both the 2.5 and 5 networks with the same ssid and password. Later found i only have a 5Ghz network, no 2.4. Disabled the 2.4 and the enabled again, no ...
- Sep 08, 2021
first we update your firmware, then we can troubleshoot the wireless.
So try updating, then do a factory reset and reinstall
callwill
I assumed that your suggestion would solve the firmware update issue so i was seeking a soulution to the other problem.
Sep 08, 2021Guru - Experienced User
