Panther_dust
Apr 29, 2019Aspirant
No access to router
So my router is being a pain in the backside, I have it connected to a bt router Lan to Lan to make use of the 5Ghz and the higher rate 2.4Ghz wireless however for some reason it keeps disappearing, b...
- Apr 30, 2019
I want to thank you both for taking the time to look at helping me however i have now sorted the issue and will explain in a sec but just wanted to answer a few quwstions here for you both
Yes the Bt Router is also my Modem
LAN - LAN so when looking at AP mode on any router its recomended you use LAN PORT (Router1/Modem) to WAN PORT on router 2 however i had very little joy with this as my IP kept setting to 169.86.x.xxx and all internet was lost HOWEVER using LAN to LAN there was still a bridged connection to router1 BT/Modem so i could still access the internet, i also found that LAN - WAN seems to be slower than LAN to LAN
the settings would be for the readyshare, the wireless name/password and turning OFF settings not needed like the DHCP as Router/modem 1 will handle that
The router is indeed a R6220, it was a typo from using my mobile, autocorrect i dont know why
i never expected it to be a router but to be an access point as you have pointed out, i have gone most of my life calling all network devices routers as that is what they all do, i mean ok, to a different extreme but still routes traffic one way or another, please forgive my simple ways
Bt router works well on sky's service, i was able to (a while ago) ssh into it and rewrite some firmware to unlock it, turning it into just another 3rd party modem, far far less droped service unlike skys pile of crap
and the IPv6 "stuff" wasnt a red herring and was actualy the cause of my problem, here is what happned
Even with a IPv4 address set manualy i somehow kept getting a v6 address, after trying many addresses (as post above) to get into the router settings page, i decided to look deeper into my ip settings, i opened up Command Prompt and did the usual IP magic ipconfig, i did send a screenshot with my last post but i dont think it went, this didnt yeald much so i used ipconfig/all which gave me a bit more detail but not enough, so i went to my ethernet adapter settings (this is all on windows 10 BTW) went into properties and unchecked the IPv6 protocal;, THIS GAVE ME ACESS!.
i was able to get into the settings page on the router and adjust the advanced settings and switch off the IPv6 on the router and HEY PRESTO! everything works, i have internet, i have access to my router page for both bt/modem and netgear and i can see all devices aswell, (which made me **bleep** myself when my Kitsound Voice1 (on full volume) said CONNECTED TO YOUR WIFI NETWORK!....)
so i cant realy explaine why it happened the way it did unless the BThub doesnt like ipv6 and its not on as sky doesnt support ipv6 yet
however i still thank you both for taking the time to help
michaelkenward
Apr 30, 2019Guru - Experienced User
Panther_dust wrote:
Ok so, connected to my houses phone socket is a microfilter, in that is my house phone and my BT homehub 3.0 router, I'm not with bt I am with sky but I unlocked an old bt one as that is all I could find cheap at the time and the sky one was crap.
Your Internet is DSL and your Homehub "router" is really a modem/router.
I am currently connected to the Netgear and editing this to the room now, so the actual internet works, these are connected LAN to LAN to avoid dual DHCP from Lan to wan and double NAT.
Not sure that I understand what LAN to LAN means, but it will not disable the router features in the Homehub. From what I have seen, that is not possible.
I suspect that this setup explains this bit:
Every time I reset the router and enter all the settings the way I want them with the hard drive working on the network, after 30 mins it then stops again and the router page can no longer be accessed, and I have to hard reset again and again and again.
The two boxes are both trying to work out what to do with various address requests.
Your message says n6220, which is not something I recognise from Netgear. But the "footer" says R6220. Maybe that is what you have.
The recommended way to disable the router bit of the R6220, and to avoid double NAT is to put it into wireless access point (AP) mode. With all that stuff "upstream of the R6220, you can't expect it to work as a router.
You say you have tried this, but it is not clear to me that the R6220 is properly configured and using the WAN input or that you have taken your network through the required startup regime.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
This means that the devices on the network get their Internet connections in the correct order.
I suspect that your stuff about IPv6 is a red herring, especially when using a BT modem on Sky DSL. Do they even use the same flavour of IPv6?
I assume that you know that the BT modem/router plays nicely with Sky's DSL.
antinode
Apr 30, 2019Guru
> [...] Netgear r6220 [...]
Firmware version?
> [...] these are connected LAN to LAN to avoid dual DHCP from Lan to
> wan and double NAT.
What is the LAN IP address of the R6220? (Set how?) Or is that part
of the mystery?
> [...] I went to take a look at the router settings and the page cannot
> be found, I have tried using several addresses, [...]
"went" _how_, exactly? From where, exactly? _Which_ "several
addresses"?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Use the Router as a
Wireless Access Point". Start with a freshly reset R6220, and do what
it says there, instead of what you have been doing. With any luck,
you'll see the R6220-as-WAP in the "devices list on the bt Homehub 3."
> want them [...]
The non-psychics in your audience don't have a clear idea of what
those "all the settings" might be.
> [...] Obviously I have tried using it as AP mode or extender mode
What's "Obvious" to you may not be so to anyone else. As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
> Not sure that I understand what LAN to LAN means, [...]
Presumably, it means that the R6220 was configured as a wireless
access point, without using the ADVANCED > Advanced Setup > Wireless AP
method.
> The two boxes are both trying to work out [...]
Not really.
> I suspect that your stuff about IPv6 is a red herring, [...]
Knowing nothing, I'd avoid thinking about IPv6.
- Panther_dustApr 30, 2019Aspirant
latest version V1.1.0.86_1.0.1
the IP was set manualy by going into setup and internet setup, i also used the BTrouter/modem to assign an ip to the mac address at all times, netgear uses 192.168.1.1 and bt uses 192.168.1.254, both default and both ends of the scale, easy to remember
went as in using a browser to the default address as my first post suggested at 192.168.2.2, routerlogin.net/.com i even tried ssh using the program PuTTy to no avail
i appreciate you pointing me to the online manuals but i have been threw it and have been working with networks and pc's for a long time, this one just completely stumped me was all
settings being AP names, Passwords USB Readyshare settings the normal
i had tried to show my actions by attaching images with my posts however they didnt seem to upload from my phone
and yes to the access point with out the access point setting being enabled, for one i find it faster than lan to WAN and two when AP mode is enabled you cannot share usb folders or drives from that router and this was my intention.
and finaly IPv6 is an absolute waste of time and the biggest headache you will ever have
again thank you both for your help, maybe not directly but you helped me keep my mind on track to figure out what was wrong
even if i dont understand why it happned
