resemo
Nov 06, 2016Aspirant
No ADSL Settings on my WNR614/N300 NetGear router
Hi All, This is my first post here. I just bought a NetGear WNR614 wireless router, and I'm having issues setting it up. The router is connected to via WAN to a ZTE router. I need to configur...
- Nov 07, 2016
If you mean how do you "set your modem in bridge mode", check the modem's manual.
But with four other routers/access points you seem to have a pretty complicated network.
You can find the documentation for your Netgear stuff here:
WNR614 | Product | Support | NETGEAR
The documentation clearly lays out the order in which you need to do things:
- Unplug and turn off the cable or DSL broadband modem.
- Unplug the router.
- Plug in the cable or DSL broadband modem and turn it on.
- Wait two minutes.
- Plug in the router and wait two minutes.
Retired_Member
Nov 06, 2016You bought the wrong router if requiring ADSL settings.
resemo
What do you mean bought the wrong router? Its out of the box. How can there be no ADSL settings in a router.
- Retired_MemberNov 06, 2016
So your suggesting all routers have a ADSL modem?
- wcalifas831Nov 06, 2016Prodigy
You probably have to set your modem in bridge mode, and then run the setup wizard so that your new router can detect what kind of internet you have.
- resemoNov 07, 2016Aspirant
How do I do that?
