resemo
Nov 06, 2016Aspirant
No ADSL Settings on my WNR614/N300 NetGear router
Hi All, This is my first post here. I just bought a NetGear WNR614 wireless router, and I'm having issues setting it up. The router is connected to via WAN to a ZTE router. I need to configur...
- Nov 07, 2016
If you mean how do you "set your modem in bridge mode", check the modem's manual.
But with four other routers/access points you seem to have a pretty complicated network.
You can find the documentation for your Netgear stuff here:
WNR614 | Product | Support | NETGEAR
The documentation clearly lays out the order in which you need to do things:
- Unplug and turn off the cable or DSL broadband modem.
- Unplug the router.
- Plug in the cable or DSL broadband modem and turn it on.
- Wait two minutes.
- Plug in the router and wait two minutes.
michaelkenward
Nov 07, 2016Guru - Experienced User
resemo wrote:The router is connected to via WAN to a ZTE router. I need to configure the ADSL settings, but its not available. I cannot input the multiplexing method or any ADSL configuration since the tab is not present.
Is that a ZTE router modem?
You'll need one modem somewhere in the system to connect to ADSL.
- resemoNov 07, 2016Aspirant
Yes, the ZTE is an ADSL router/modem, which feeds 4 other routers/access points - with seperate SSIDs.
The problem is that the NetGear doesn't want to detect the internet connection signal, and there are no ADSL settings.
Not sure what the problem is tbh.
