resemo's avatar
resemo
No ADSL Settings on my WNR614/N300 NetGear router
Hi All,   This is my first post here. I just bought a NetGear WNR614 wireless router, and I'm having issues setting it up.   The router is connected to via WAN to a ZTE router. I need to configur...
  • michaelkenward's avatar
    michaelkenward
    Nov 07, 2016
    If you mean how do you "set your modem in bridge mode", check the modem's manual.
    But with four other routers/access points you seem to have a pretty complicated network.
    You can find the documentation for your Netgear stuff here:
    WNR614 | Product | Support | NETGEAR
    The documentation clearly lays out the order in which you need to do things:
    • Unplug and turn off the cable or DSL broadband modem.
    • Unplug the router.
    • Plug in the cable or DSL broadband modem and turn it on.
    • Wait two minutes.
    • Plug in the router and wait two minutes.
