resemo
Nov 06, 2016Aspirant
No ADSL Settings on my WNR614/N300 NetGear router
Hi All, This is my first post here. I just bought a NetGear WNR614 wireless router, and I'm having issues setting it up. The router is connected to via WAN to a ZTE router. I need to configur...
- Nov 07, 2016
If you mean how do you "set your modem in bridge mode", check the modem's manual.
But with four other routers/access points you seem to have a pretty complicated network.
You can find the documentation for your Netgear stuff here:
WNR614 | Product | Support | NETGEAR
The documentation clearly lays out the order in which you need to do things:
- Unplug and turn off the cable or DSL broadband modem.
- Unplug the router.
- Plug in the cable or DSL broadband modem and turn it on.
- Wait two minutes.
- Plug in the router and wait two minutes.
resemo
Nov 07, 2016Aspirant
How do I do that?
michaelkenward
Nov 07, 2016Guru - Experienced User
- Wait two minutes.
