miguelangelnet
Oct 12, 2021Guide
No Internet - CBR750
Hardware Version CBR750 Orbi Firmware Version V3.2.18.2_1.4.14 I have WiFi (no issues here), but I don't have internet, pink light at the bottom of the router, and 2 orange lights for output and...
michaelkenward
Oct 13, 2021Guru - Experienced User
A lot of questions are generic and apply to most devices, but in this case there is just about nothing that your CBR750 has in common with the "General WiFi Routers (Non-Nighthawk and Non-Orbi)" covered in this section.
Your thing is an Orbi device and a modem/router to boot.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi with Built-in Cable Modem - NETGEAR Communities
If you do post there, you might find it useful to explain what else you have on the network. For example, you described your CBR750 as a router. It is more than that. I assume that you don't have another modem sitting in front of your box.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
