Reactant
Jan 09, 2011Initiate
No Internet Access - but still connected?
Hi, I've been having this problem for some time now, and up until this point, it's been nothing more than a nuisance. However, I've finally just had it. I have a WGR614 v7 wireless router, and for...
- Apr 15, 2012Believe it or not I did, for the most part.
Like most wireless routers, every couple of days, or a week or so, this problem will present it self and I cant get any internet. The solution I found was to open the Router Manger (http://192.168.1.1/start.htm from a browser) and click the "Setup Wizard" link on the left. All I do is re-run the wizard and it seems to restart the router software. All devices will disconnect and then reconnect and it usually works. Sometimes I need to do this process a few times but it usually takes care of it.
Please let me know if this works for you or not, or if you figure out something else, thanks.
-Trevor
ronpadz
I am having same problem and want to join the thread. I'm about to give up on this router.
