Reactant
Jan 09, 2011Initiate
No Internet Access - but still connected?
Hi, I've been having this problem for some time now, and up until this point, it's been nothing more than a nuisance. However, I've finally just had it. I have a WGR614 v7 wireless router, and for...
- Apr 15, 2012Believe it or not I did, for the most part.
Like most wireless routers, every couple of days, or a week or so, this problem will present it self and I cant get any internet. The solution I found was to open the Router Manger (http://192.168.1.1/start.htm from a browser) and click the "Setup Wizard" link on the left. All I do is re-run the wizard and it seems to restart the router software. All devices will disconnect and then reconnect and it usually works. Sometimes I need to do this process a few times but it usually takes care of it.
Please let me know if this works for you or not, or if you figure out something else, thanks.
-Trevor
jmizoguchi
Jan 09, 2011Virtuoso
see router setup on my sig below. make sure broadband and router is setup correctly. this will be first steps.. if this not correctly done you will have issues
either did not detail enough on type of broadband, before post any read and see if you setup is right and if so then explain why it is okay.
this will be a start...
