Reactant
Jan 09, 2011Initiate
No Internet Access - but still connected?
Hi, I've been having this problem for some time now, and up until this point, it's been nothing more than a nuisance. However, I've finally just had it. I have a WGR614 v7 wireless router, and for...
- Apr 15, 2012Believe it or not I did, for the most part.
Like most wireless routers, every couple of days, or a week or so, this problem will present it self and I cant get any internet. The solution I found was to open the Router Manger (http://192.168.1.1/start.htm from a browser) and click the "Setup Wizard" link on the left. All I do is re-run the wizard and it seems to restart the router software. All devices will disconnect and then reconnect and it usually works. Sometimes I need to do this process a few times but it usually takes care of it.
Please let me know if this works for you or not, or if you figure out something else, thanks.
-Trevor
JtP
Aug 25, 2012Initiate
I am having the same problem described here on my 15 month old DSL Router (DGN 2200(B) Wireless N300 Modem Router). The connected (wired connection) works, but the wireless connections fail. Sometimes it resolves itself, sometimes a reboot fixes it. On the most recent occasion, the reboot didn't work, but 30 minutes later it resolved itself.
I called Netgear and they offered to sell me a service contract, not very helpful there. For the price of 12 mos unlimited service, i can buy another router!!
