eickmewg
Nov 27, 2015Tutor
No internet connection with new AC1750 R6400 router
We just got a Netgear CM500 modem and AC1750 R6400 WFi router. The Comcast activationof the modem was successul, but when I then hooked the router to the modem and the computer to the router via et...
- Nov 28, 2015
Yes, those connections are correct. From your computer, enter routerlogin.net into a browser. This should automatically connect you to the router. You will need to enter the username and password for the router. The defaults are admin and password, respectively. You should change the password.
Dmonahan01
Jul 21, 2016Aspirant
I have tried this but it did not work. Any other suggestions?
- TheEtherJul 21, 2016Guru
Dmonahan01 wrote:
I have tried this but it did not work. Any other suggestions?You should start your own thread. Describe your setup, exactly what you tried and what you observed. It's not possible for us to help without this information.
