chanimnms
Mar 21, 2017Follower
No internet connection with new AC1750 R6400 router
ok so I did EVERYTHING correct and all the white lights are on and I reset and restarted and it just isn't working. Tried to connect on the phone and still no. It will NOT go to the genie configura...
- Apr 19, 2017
Hi Omclaughlin,
1. Please check if the issue (slow streaming) persists when connected straight to the modem.
2. Does the issue persist on all your devices (wired and wireless)?
3. What is your subscription speed?
4. You can try changing the MTU. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/19863
http://kb.netgear.com/app/answers/detail/a_id/25675
Dexter
Community Team
Omclaughlin
Apr 19, 2017Aspirant
Do a factory reset and then follow then power down and then follow order of powering back up
DexterJB
Apr 19, 2017NETGEAR Moderator
Hi chanimnms,
1. Please make sure that your computer is able to go online when connected straight to the ISP's modem.
2. You can try MAC spoofing (for cable connection). Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
