longsilver
Aug 21, 2020Aspirant
No internet connection with new AC1750 R6400 router
I cannot get my R6400v2 to get internet access from my optical ONT (modem). The frustrating part is that the R6400v2 worked fine initially, but for some reason it stopped getting internet access. If...
ampvick
Jan 07, 2021Aspirant
Are you still having this issue. My router occasionally pull a 192.168.1.2 address on the WAN side, with 192.168.1.1 address for the gateway. When this happens I have no internet access. If I go to 192.168.1.1 it brings me to an R6400 webpage, which I think maybe the XR300 is based on the R6400. I was blaming my ISP, but maybe this is actually a router issue.
longsilver
Jan 10, 2021Aspirant
It is hard to say if the problem still exists. This problem was persistent, but eventually it worked for some reason. After I reset my router to factory defaults several times I was able to get it setup and working. Currently the router works but shows no WAN connection. If for some reason I get a power drop out I believe this problem may occur again.
- olympos1625Jan 14, 2021NETGEAR Employee Retired
Hi longsilver,
Good day!Welcome to NETGEAR Community!
First of all, we do apologize for the inconvenience of not getting back to you immediately due to the backlog in the system. Have you tried contacting our Support team before? If yes, can we have the case number? Did you have this problem from the beginning?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
