J_Jefferson
Nov 11, 2020Aspirant
No internet connection
Unit has been working for years. Suddenly, when trying to connect, get message " Wi-Fi doesn't have a valid IP Configuration". Therefore, cannot connect to either of the 4 ports or thru Wi-Fi. Pow...
J_Jefferson
Nov 12, 2020Aspirant
I thought I had everything in the message. Netgear AC1750 Smart WiF Router, 02.11 ac dual Bank Gigabit, Model No: R6400v2, (R6400-100NAS), firmware V1.0.4.78. Cannot get internet connection to try to update firmware. Tried to use NightHawk app on android phone and routerlogin.net.genie but since no internet connection, this failed.
It is connected to Xfinity modem XB6-T. Tested with an old Linksys router so I know there is not a problem with the modem connection to the router. Reason I switched to the NetGear AC1750 was to get more WiFi range.
Nov 12, 2020Guru - Experienced User
that xfinity modem is a router as well. It puts you in a double nat. Some handle it better than others.
https://kb.netgear.com/30186/What-is-Double-NAT
have you disabled the routing functions on the xfinity?
or put the netgear in access point mode?
- J_JeffersonNov 12, 2020Aspirant
I have done nothing to the xfiniity (modem/router) It has worked perfectly for 2 years. I believe the router just might be bad.
I cannot access or update the software on the NetGear router because I have no wifi on the unit. Old routers will work.
- wcalifasNov 13, 2020Prodigy
did you try restarting the netgear router? you can also try resetting the router back to defaults again by pushing the reset button for 30 seconds. Did you try any of those?
- J_JeffersonNov 13, 2020Aspirant
Yes did a restart and tried resetting the router back to defaults. Still no WiFi light. Cannot access off-line or at least what I tried did not work. I believe it it just might be DEAD.
