J_Jefferson
Nov 11, 2020Aspirant
No internet connection
Unit has been working for years. Suddenly, when trying to connect, get message " Wi-Fi doesn't have a valid IP Configuration". Therefore, cannot connect to either of the 4 ports or thru Wi-Fi. Pow...
Nov 13, 2020Guru - Experienced User
V2 is better.
Are any of the led's on? If its a corrupt firmware issue, a tftp or nmrp flash procedure could fix it.
wcalifas
Nov 13, 2020Prodigy
Try 192.168.1.1 or http://routerlogin.net on your browser.
- J_JeffersonNov 14, 2020Aspirant
OK, making progress. Trying a firmware update. Connnected NetGear router to laptop via ethernet cable. Plugged into port 1. Laptop is not conected to Xfinithy router but connected via Wifi. Was able to get inot NetGear page using ip addresses you referred to so it must be readying data of router. Firware verson V1.0.4.78_10.0.55, Advanced tab shows Netgear Router information, Wireless Settings for 2.4GHz and 5GHz, but Interenet port shows a yellow triangle with !. No ethernet plugged into the routner internet port.
On the left menu, if I clck on NetGear Downloader, nothing happens, probably becuase there is not connection.
I went to Advanced Settings > Adinistration > Router Update > Got a file I had download to a thumbdrive but when trying to apply said is was a *chk file. I downloaded another file to my lap top (icon of books) R6400v2.V1.0.4.102_10.0.75 which is a zip file. This may just be documentaton. Amy pointers as how to proceed.
- wcalifasNov 14, 2020ProdigyOpen the folder and drag it out from that folder and set it out on your desktop and then apply the update manually. Click the file from the desktop when it asks you where you want to choose the file from.
Think we are making some progress. Please look at my documentation attached that shows screen shots of my progression. Appeared upload was working but after completion, got "No Connection". What is next step. The last screenshot is for Interent Setup, which is blank. Maybe this page has to be setup. Thought it would update automatically, so could this be why I have no WiFi connection? What data needs to go here?
