Nickcurle
Feb 26, 2021Follower
No internet connection
I bought a new net gear AC1750 model R6350. I hooked everything up as directed. But I’m only getting two green led lights and no internet signal l. How do I fix this?
antinode
Feb 26, 2021Guru
> I bought a new net gear AC1750 model R6350. [...]
Ok. Why? New installation? Replacement for some gizmo in a
previously working arrangement? Addition to some previously working
arrangement? Other?
> [...] I hooked everything up as directed. [...]
What, exactly, did you hook up to what, exactly? (Hint: If a device
has different types of Ethernet ports, then "connected to device" is not
enough detail.) "as directed" by what/whom? Is there some kind of
modem involved? What is _it_ doing?
> [...] But I'm only getting two green led lights [...]
Do you think that the _number_ of lights is the most important fact
here?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
LED descriptions and "Troubleshoot"? Further reading might not hurt,
either.
