tperk
Jun 08, 2021Aspirant
No Internet on Firestick w EX6120 or 7300
This is a strange problem. Firestick connects OK with Internet on Router 2.4 or 5.0 Have 2 NetGear Extenders, EX6120 and EX7300. Firestick connects to network but will not connect with Internet ...
Jun 08, 2021Guru - Experienced User
What modem do you have?
What router are they connecting to?
Did you setup the extenders using wps or using the installation assistant?
Are you using any special characters/spaces in your ssid/password? (if so, remove them)
tperk
plemans wrote:What modem do you have? Verizon FIOS G-1100 Gateway
What router are they connecting to? Verizon FIOS G-1100 Gateway
Did you setup the extenders using wps or using the installation assistant? WPS
Are you using any special characters/spaces in your ssid/password? (if so, remove them) No
Firestick connects OK directly to Gateway. PWs for Extender Nets are same as Gateway Nets. Here is example T3Batsarecrazy250
Other suggestions?
Thanks much
Tom
- plemansJun 08, 2021Guru - Experienced User
Did you try setting the extenders up using the installation assistsant? I'd give that a shot.
- tperkJun 08, 2021Aspirant
plemans wrote:Did you try setting the extenders up using the installation assistsant? I'd give that a shot.
Not going to go through assstant at this point. I may have used it though because I set the extenders to static IP. Do you think it could have anyting to do with me assiging static IPs to the extenders?
I am ordering a 2cnd Firestick for another TV in next few weeks. When it comes in I will see if it will connct through Extenders. I will take it from there.
Thanks for your help
