tperk
Jun 08, 2021Aspirant
No Internet on Firestick w EX6120 or 7300
This is a strange problem. Firestick connects OK with Internet on Router 2.4 or 5.0 Have 2 NetGear Extenders, EX6120 and EX7300. Firestick connects to network but will not connect with Internet ...
tperk
plemans wrote:What modem do you have? Verizon FIOS G-1100 Gateway
What router are they connecting to? Verizon FIOS G-1100 Gateway
Did you setup the extenders using wps or using the installation assistant? WPS
Are you using any special characters/spaces in your ssid/password? (if so, remove them) No
Firestick connects OK directly to Gateway. PWs for Extender Nets are same as Gateway Nets. Here is example T3Batsarecrazy250
Other suggestions?
Thanks much
Tom
Jun 08, 2021Guru - Experienced User
Did you try setting the extenders up using the installation assistsant? I'd give that a shot.
- tperkJun 08, 2021Aspirant
plemans wrote:Did you try setting the extenders up using the installation assistsant? I'd give that a shot.
Not going to go through assstant at this point. I may have used it though because I set the extenders to static IP. Do you think it could have anyting to do with me assiging static IPs to the extenders?
I am ordering a 2cnd Firestick for another TV in next few weeks. When it comes in I will see if it will connct through Extenders. I will take it from there.
Thanks for your help
