mmar0802
Jun 22, 2016Aspirant
No Internet To Router
My router has been set up for 3 years with no problems at all. A couple days ago the power went out breifly and we lost the wifi connection. I logged into Netgear Genie and attempted to reset every...
- Jun 22, 2016
I unplugged everything for the 100th time and plugged it all back in, in the order the instructions say to do it. I swear I did that already a bunch of times but today it actually worked. It has to go in this order or it doesn't pick up internet.
1. Unplug everything, including modem
2. Plug in modem and wait for it to fully power on
3. Attach Ethernet from modem to router
4. Turn on router, Internet light should turn green
5. Set up wifi network
6. Connect to network on devices
this only worked with the new router I bought though, the old one still won't work. It connects to the Internet but no wifi. I've decided to call it a loss and move on with the new router
mmar0802
Jun 23, 2016Aspirant
No it still turns on, Internet light turns green, but no wifi signal appears in list and if you plug Ethernet in to one of the ports, that doesn't work either. I have tried to ping it, and several other advanced troubleshooting procedures. Nothing works. It doesn't make sense.
