Internetstuff
Sep 23, 2020Aspirant
No Internet
I am in Australia. I have been advised that my D6200 modem/router will not work with NBN as it does not have VLAN capability. However, it will work if I upgrade the firmware. IS THIS CORRECT? ...
- Sep 28, 2020
I have upgraded to .40
It enables the VLAN to be set. (iiNet told me it had to be set to 2).
Internet now works fine.
Internetstuff
Sep 24, 2020Aspirant
Thank you. It was my ISP that advised I needed VLAN capability. It was a Netgear Community discussion that stated that a firmware upgrade would give me that capability. The article you provided (Manual Firmware Upgrade) was very useful thanks. I downloaded the new file using the instructions in the article, which worked fine. Unfortunately when I try to upload the file on to the modem, the rectangular box fills with vertical lines and - above that box - the "Spinning" icon keeps spinning. I have tried multiple times with the same result.
I will start another discussion on that particular issue.
Thank you again.
Internetstuff
Sep 28, 2020Aspirant
