DSLPTx0
Jan 23, 2016Aspirant
No IP address obtained from WAN connection
Ok, so this morning I reset my modem and router, because my connection seemed to slow down by quite a bit, and I started having trouble staying connected on my ps4. But after everything came back up, ...
- Jan 27, 2016Ive seemingly fixed the problem by enabling IPv6. But I was trying a playstation 4, and my windows 10 running desktop. My 2.4 was already on channel 11. And what I meant by getting through the SSID I meant that I'd put in the password, it'd accept the password, but it wouldn't get an IP address.
Retired_Member
Jan 25, 2016try a factory default and then reload FW same problem replace it.
