TheHawaiiYankee
Oct 12, 2021Initiate
No Password on 2.4ghz
Hello! I recently purchased and set up a Netgear C6300. When utilizing NETGEAR genie, I've found that I am able to change the name of both the 2.4Ghz and 5Ghz channels but when I attempt to update th...
- Oct 12, 2021
A couple things.
1. do you have a screen snip of the cable connections page and the event logs?
2. have you tried a factory reset/reinstall?
3. have you tried using a different browser/pc to set the password?4. Next time, you might get better help in the cable modem/router forum versus the standard router forum.
TheHawaiiYankee
So it ended up working out, I had factory reset it once, attempted the settings from different pc/mobile/the Nighthawk App to no avail, but after factory resetting it the second time it worked out. Thank you very much for the help!
Oct 12, 2021Guru - Experienced User
Glad it fixed the issue!
let us know if you have other issues
