Randin
Dec 12, 2017Aspirant
No QoS controls to be found? AND slow wired speed relative to modem
Where are the QoS controls for this router? The QoS tab does not exist where all online links indicate for other models.Nor does the long button to create a QoS rule. QoS is also not mentioned anywhe...
- Dec 13, 2017
Think I found the answer to the degraded speed. The modem LAN light is green when a 1Gb connection is made, as when I am wired directly to the modem. When I wire the router to the modem, the LAN light is amber indicating 10/100 or 100mbps connection. Someone else with the same situation [but different, parallel equip] was told he needed to get a gigabit router so the modem LAN is green, not amber, indicating a 10/100/1000 port. He did that and it fixed his problem. Am returning the R6080 for an AC1200 R6230. Hope that will do the trick. AND the 6230 also has QoS controls.
Randin
PS Firmware was auto-upgraded when I started the router, which I just got yesterday. Current FW v1.0.0.22. (Sorry didn't see an edit button to edit my OP.)
