kwdavids
Mar 29, 2018Aspirant
"No ReadySHARE device detected"
I'm trying to setup ReadyShare on my R6200v2 router (Firmware v1.0.3.12). I have a PC hardwired to the router. Web access to the router shows the hard drive installed. I Installed Genie on the PC...
- Mar 29, 2018
Thanks.I read up on SMB1 and ReadySHARE and solved the issue.
In order for the ReadySHARE drive to be accessed, I had to go to Control Panel | Programs and Features | Turn Windows features on or off | SMB 1.0/CIFS File Sharing Support | SMB 1.0/CIFS Client and set that ON and reboot.
If I understand what I read, the WannaCry vulnerability is with the Server, not the Client, and enabling the Client won't cause a problem.
I'm running Windows 10 Version 1803, Build 17133.1.
antinode
Mar 29, 2018Guru
What exactly, shows what, exactly? What's listed under (BASIC >
ReadySHARE) "Available Network Folders"?
> I also cannot access the drive from Windows using \\name.
"cannot" is not a useful problem description. What happens when you
try?
Windows version? A Web or Forum search for keywords like:
ReadySHARE smb1
might find some interesting (or depressing) information.
kwdavids
