KristenH21
May 31, 2021Aspirant
No wifi connection outside home
Hi there. A few years ago, I brought a new Netgear router and registered it here at Netgear. I've used to have wifi service outside of my home like earlier this year and last year in my apartment lik...
michaelkenward
Jun 01, 2021Guru - Experienced User
KristenH21 wrote:
Hi there. A few years ago, I brought a new Netgear router and registered it here at Netgear. I've used to have wifi service outside of my home like earlier this year and last year in my apartment like when I go downstairs or even to my doctor's appointments.
A router in your home is not going to provide wifi more than a few feet outside the building, if that, certainly not to a doctor's appointments unless you live in the same building as the doctor.
The WNR2000v5 is an ageing (2014 for V5 with its first version in 2008) router. It has very old technology, both for wifi and for wired connections.
KristenH21
Jun 01, 2021Aspirant
OKay. That makes sense on why I can't connect online outside my apartment building. So you suggest that I should update my router with a newer one that has a wider ranger for wifi or to extend it?
- michaelkenwardJun 01, 2021Guru - Experienced User
A new router will not make your wifi go much further than your apartment. That's not what wifi is for. You mobile phone does that using your cellular service.
But most modern mobile phones will connect to any wifi service that allows them to login. That has nothing to do with your router. You need to do it on the phone.
- KristenH21Jun 01, 2021Aspirant
OH okay. I do have wifi with my smartphone. But I don't know how to extend it further if remotely possible. I guess I should call my cell provider then.
