Fumanchu1021
May 29, 2021Aspirant
No WiFi connection
I started having this issue last week and have never encountered this before. If I’m outside my house and I connect to the Orbi through the app via “connect anywhere access” it says it’s online & conn...
May 30, 2021Guru - Experienced User
1. What actual orbi do you have?
2. what firmware is on it?
3. what gateway/modem is it connected to?
Fumanchu1021
May 30, 2021Aspirant
It’s an Orbi AC3000 mesh router with one satellite. Firmware is V2.7.2.104 and connected to Motorola MB8600 modem.
- plemansMay 30, 2021Guru - Experienced User
on the orbi, try disabling daylight savings time and then the traffic monitor. then reboot the router.
there's been a lot of posts about the .104 firmware.
did this just start? was it working before?
- Fumanchu1021May 30, 2021AspirantYes it just started about a week ago, was working fine before.
- Fumanchu1021May 30, 2021AspirantWhere do I go to disable those two things? Thanks.
