Needynoob
Dec 30, 2020Aspirant
No WiFi even after factory reset
After nearly a year, I can no longer connect to my Orbi WiFi. The WiFi is visible, but I am “unable to connect” to it. This has happened before, maybe once a few months ago and then more persistently ...
tomdayne001
Feb 03, 2021Aspirant
You can check the following tips. Hope it does work!
- Update the firmware and any apps that need updating on the phone.
- If the problem persists, check your time and date on the phone to make sure it is correct.
- Should none of the former work...
1. Clear out the WiFi data on the phone.
2. Reboot the modem/router.
3. Once the modem/router is fully 'up' again, reboot the phone and re-input the WiFi data.
