cuppycake
Feb 23, 2017Aspirant
No Wifi, Netgear N600
My wifi was working fine until last night. I noticed my android phone wouldn't connect but figured it was my phone... Today, my husband's phone and television will not connect. My pc is connected t...
- Feb 24, 2017
try to factory reset the device, just saying.
Then delete the wifi phones connection.
And finally reconfigure your network.
aalexandrebeta
Feb 23, 2017Master
Did you pushed the wifi on/off switch that kill wifi?
If not try factory reset and reconfigure!
- cuppycakeFeb 23, 2017Aspirant
No, the wifi on/off switch was not pushed initially.
I was trying to avoid factory reset and reconfiguring, the troubleshooting above is the exent of my knowledge with pcs and hardware! Reconfiguring is pushing it! :smileyembarrassed:
- aalexandrebetaFeb 23, 2017Master
Did you try to reboot your wifi devices?
- cuppycakeFeb 24, 2017Aspirant
Yes, we tried forgetting the network... turning off devices and turning them on and reconnecting...
I looked at the connected devices through genie and it shows the pc is connected...it gives a mac address, which I am assuming is one of our cell phones... Today, my phone says authentification error...when failing to connect to the network..
