cuppycake
Feb 23, 2017Aspirant
No Wifi, Netgear N600
My wifi was working fine until last night. I noticed my android phone wouldn't connect but figured it was my phone... Today, my husband's phone and television will not connect. My pc is connected t...
- Feb 24, 2017
try to factory reset the device, just saying.
Then delete the wifi phones connection.
And finally reconfigure your network.
cuppycake
No, the wifi on/off switch was not pushed initially.
I was trying to avoid factory reset and reconfiguring, the troubleshooting above is the exent of my knowledge with pcs and hardware! Reconfiguring is pushing it! :smileyembarrassed:
aalexandrebeta
Feb 23, 2017Master
Did you try to reboot your wifi devices?
- cuppycakeFeb 24, 2017Aspirant
Yes, we tried forgetting the network... turning off devices and turning them on and reconnecting...
I looked at the connected devices through genie and it shows the pc is connected...it gives a mac address, which I am assuming is one of our cell phones... Today, my phone says authentification error...when failing to connect to the network..
- aalexandrebetaFeb 24, 2017Master
Update: I have not factory reset just yet..
However, I changed the security setting to NONE from WPA2-PSK [AES] and my phone picked up the wifi without a problem...
Suggestions?
