cuppycake
Feb 23, 2017Aspirant
No Wifi, Netgear N600
My wifi was working fine until last night. I noticed my android phone wouldn't connect but figured it was my phone... Today, my husband's phone and television will not connect. My pc is connected t...
- Feb 24, 2017
try to factory reset the device, just saying.
Then delete the wifi phones connection.
And finally reconfigure your network.
michaelkenward
Feb 24, 2017Guru - Experienced User
Go into the web interface and look at the wifi settings to ensure that they haven't turned themselves off:
WNDR3400v2 | Product | Support | NETGEAR
Tell your wifi clients to forget the home wifi network and see if you can reconnect.
An easy way to look at what is happening is to use the Netgear standalone genie application. You can get that from the same link.
The Network Map will show what is connected.
The Router Settings will let you look at the Wireless Settings.
