cuppycake
Feb 23, 2017Aspirant
No Wifi, Netgear N600
My wifi was working fine until last night. I noticed my android phone wouldn't connect but figured it was my phone... Today, my husband's phone and television will not connect. My pc is connected t...
- Feb 24, 2017
try to factory reset the device, just saying.
Then delete the wifi phones connection.
And finally reconfigure your network.
cuppycake
Feb 24, 2017Aspirant
Yes, we tried forgetting the network... turning off devices and turning them on and reconnecting...
I looked at the connected devices through genie and it shows the pc is connected...it gives a mac address, which I am assuming is one of our cell phones... Today, my phone says authentification error...when failing to connect to the network..
aalexandrebeta
Feb 24, 2017Master
- cuppycakeFeb 24, 2017Aspirant
Update: I have not factory reset just yet..
However, I changed the security setting to NONE from WPA2-PSK [AES] and my phone picked up the wifi without a problem...
Suggestions?
- wcalifas831Feb 24, 2017Prodigy
If it connected, try putting security back on the router with a password.
