toyne's avatar
toyne
no wifi signal
since i changed the light settings i have huge problems with this stupid device. before it was working perfectly     i switched my lights to off (so only the power light is lit) and while i did th...
  • Retired_Member's avatar
    Retired_Member
    Oct 20, 2016
    look for a wifi off on button on router, and or push reset until power LED flashes
