toyne
Oct 20, 2016Aspirant
no wifi signal
since i changed the light settings i have huge problems with this stupid device. before it was working perfectly i switched my lights to off (so only the power light is lit) and while i did th...
- Retired_MemberOct 20, 2016look for a wifi off on button on router, and or push reset until power LED flashes
toyne
already turned the device on/off several times. that didnt work.
like i said already resetted the whole thing twice as well
Retired_Member
Oct 20, 2016did you Factory default it?
- toyneOct 20, 2016Aspirant
i factory resetted 6 days ago and that made the problem solve, switched the lights out again and now 6 days later same problem.
before that was a shorter time periode
but i dont suppose factory resetting every week will be the sollution
- Retired_MemberOct 20, 2016Just asking the questions to try and help, Suggest you contact support they get paid to help.
Good Day!- toyneOct 20, 2016Aspirant
thought you where support, my bad.
when i tryed to contact it it lead me here.
ty for trying, know the email/way to contact support?
