Detzi8's avatar
Detzi8
No write permission on Readyshare after upgrade to V1.0.1.32_1.0.23
Hi there,
after i updated my firmware to V1.0.1.32_1.0.23 , all my linux maschines which use cifs to mount the readyshare have now no write permissions anymore.
The line used with fstab is:
//192.168.1.1/usb1 /home/mr87/readyshare cifs ,guest,uid=0,gid=0,rw,auto,file_mode=0777,dir_mode=0777 0 0
It has worked fine for many Months now and i didn't change anything else besides the update.
What do i have to change to make it work again?
Thanks in foreward
Detzi
  • For whatever reason i now have to specificly add my gid and uid . Mounting it as root does not give write permissions to the other users anymore. So i guess it is not router related.
1 Reply
