Goodglenda
Oct 31, 2020Aspirant
Non nighthawk router
My question is why would a nighthawk 2200 router show up on my wifi list when I’ve never downloaded or owned one??? I can’t get it to go away and I’m not sure why or where it came from in the last upd...
Goodglenda
I have only an eero router with wave cable I should add along with Norton VPN and security but eero is the router so I don’t believe there should be a nighthawk in there as no one has put one in our house and the neighbor’s list is still down below my list so I’m worried that it’s something done dishonestly as I’ve had much trouble with a former friend doing all she can to hack into my life
Goodglenda
I’ll stay on this site for awhile to see if someone smarter than I can help or has an idea why that would be before I have to call and have long wait times on the phone tomorrow thank you!
- antinodeOct 31, 2020Guru
> list [...]What, exactly, do you see on your "my wifi list"?
What's a "nighthawk 2200 router"?
Do you have neighbors who might have their own wireless networks? Do
you think that your (unspecified) wireless device can distinguish
between your wireless router and your neighbors' wireless routers?> I have only an eero router [...]
If you power it off, does the unwanted "a nighthawk 2200 router"
remain in your "my wifi list"?> [...] the neighbor's list [...]
You have only one neighbor? With only one wireless router or access
point?
> [...] before I have to call [...]"call" whom? Do you think that any remote person can find the source
of the "a nighthawk 2200 router" in your "my wifi list"? How, exactly
do you think that that would work?- wcalifasNov 02, 2020Prodigy
It shows up cause probably one of your neighbors has that router.
