vernonf
May 19, 2025Aspirant
not connecting to fibre
I have a DGND3700 that I wish to use as a second router however I cannot log in to the internet on my 74mbs access. It just will not connect . I need to adjust the IP address to 192.168.1.x and until...
May 19, 2025Guru - Experienced User
You might check to see if the DGND3700 has an access point mode. Or if its a v1, there's a version of ddwrt that can be installed to it. Its 3rd party firmware so can brick your device but it does add in some capabilities. Again, what use is there for a very old/slow DGND3700
