cletizio
Jul 17, 2020Initiate
Not getting full wired speeds R6100 connected to a CM1000 Modem
So like the title says, I have my desktop directly wired into my R6100 Router. My router is wired into my CM1000 Modem with Xfinity as my provider. When I connect directly to my modem I'm getting 700...
- Jul 19, 2020
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN on that device support only 10BASE-T or 100BASE-TX wired Ethernet. That makes it significantly slower than your Internet service.
Nothing will work faster than 100 Mbps on that router.
It was first released in 2013, but even then it is puzzling that Netgear would have released something that slow then.
cletizio wrote:
Also I just upgraded the firmware to 1.0.1.28
Sadly, this will do nothing to update the hardware.
antinode
Jul 17, 2020Guru
> Not getting full wired speeds R6100 [...]
How would you define "full wired speeds" for an R6100?
